4l60e to 350th
Old Mar 9, 2009 | 06:25 PM
lifeisgood's Avatar
Default 4l60e to 350th
when doing the conversion, do you have to run a full manual valve body?
and what all did you have to change in the wiring? i know the torque arm and cross member ect......... just wondering what mechanical you changed
Old Mar 9, 2009 | 06:37 PM
performabuilt's Avatar
LS1Tech Sponsor
You can run auto or full manual. You would program the PCM to a t56 program.
This is one swap I dont get however. You loose so much OD, lOCKUP (unless you use a lockup 350) and IMO the trans is not much if any stronger than a well built 4L60E.
When I was a kid we used to upgrade from these to TH400 because we would break them with 350 and 400 hp engines.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 9, 2009 | 11:23 PM
tptransmission's Avatar
Closed ex-Sponsor Account
I would agree with Frank. The bottom half of the 4l60e was derived from the t350. With proper upgrades it will work just fine.
