Hardcore tech question
Old Mar 9, 2009 | 08:42 PM
PedaltoMetal's Avatar
Default Hardcore tech question
So when the 3-4 piston is applied, it also moves the overrun piston. (forward is already applied). How is the overrun clutches not applied? Does the 3-4 piston just not move far enough? Maybe the overrun springs are stronger than the 3-4 springs. Maybe I just answered my own question. Professionals please chime in.
Old Mar 9, 2009 | 08:53 PM
9000th01ss's Avatar
It doesn't move the over run piston. It pushes the second gear servo to release the band and this also acts as the third accumulator.
Old Mar 9, 2009 | 09:41 PM
It does move the overrun piston. If you look at the stack up, it's impossible for it not to. Plus I watched it do it. Don't know what you were answering with that second sentence. But thanks for the reply, I'll listen to any ideas.
Old Mar 9, 2009 | 11:56 PM
tptransmission's Avatar
Closed ex-Sponsor Account
The 3-4 piston does not apply the overrun. Overrun is only on in Manual d3, d2 and d1.When you air check it you may be getting some leakage in that circuit or you are missing the green o'ring on the input housing.
Old Mar 10, 2009 | 07:54 AM
I know it's not applied unless in manual 321. I'm just saying it is moved by the 3/4 piston. ALL I'm asking is what keeps it from applying the overrun. Does it just not move far enough?
Old Mar 10, 2009 | 09:15 AM
performabuilt's Avatar
LS1Tech Sponsor
The 3-4 piston does not move the overun . The overun apply is in the forward clutch piston. Now it does move up with the forward clutch but still does not apply the overun.
The very first piston in the drum is the 3-4. Then you have the forward and overun in the next set and the 3-4 and those are isolated from each other. If the overun is moving when you apply the 3-4 you have a problem a leak as mentioned or perhaps you are confusing the forward clutch set with the 3-4?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 10, 2009 | 11:03 AM
Thats all I wanted to hear. I was hoping you would come to the rescue. thanks
