A4 Brake Pedal Assembly
The assemblies look totally different when you look at them.. I do not know if the pedals will swap in and out.. I do know that the assemblies mount totally different.
Basically there are about 10 or so bolts (Gold 14mm I believe) that hold the whole assembly in.. On the M6 there is one right above the steering column that is a bitch to get off. Once you get all of them out, the assemblies come out in one bracket/piece
