Shift Points?
Old Mar 11, 2009 | 06:14 PM
Tee1up's Avatar
Default Shift Points?
Where are good 1,2 shift points in (mph) for a performa built lev2 and 408 with 3.89 gr? i plan to set limiter at 6800
Old Mar 11, 2009 | 07:23 PM
performabuilt's Avatar
LS1Tech Sponsor
That varies with the car and the converter. and ussually requires a bit of trial and error unless the tuner is very familiar with your car and power.
Its affected by everything from as i said the stall, The engine power , rear ratio.
And the setting must be ajusted in both MPH and RPM
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 11, 2009 | 09:08 PM
SOMbitch's Avatar
A street tune or Dyno will help you nail it. If it is a new tranny there are a few other things that should be looked at too.....
