Disconnecting transmission lines...
Old Oct 19, 2003 | 04:55 PM
jruss's Avatar
Default Disconnecting transmission lines...
How would I go about disconnecting the tranny lines in a 4L60E? TIA
Old Oct 19, 2003 | 05:20 PM
2xLS1's Avatar
Default Re: Disconnecting transmission lines...
Use an ice pick or a scribe with a 90 degree bend about 1/2 inch from the end. Pop out the 2 wire e clips in the connectors and the line pull right out. To reassemble, put the e clips back in the tranny first, then just push the lines in until you hear them click.
Old Oct 19, 2003 | 05:34 PM
jruss's Avatar
Thanks very much for the great help and fast response!
