Tranny Help
Old Mar 17, 2009 | 12:11 PM
InsaneDomestics's Avatar
Default Tranny Help
I have a 98 Camaro and I just Swapped in a 6.0. When I had the tranny out I lost alot of fluid from the TC. I got everything put back in the car and started her up, but she wouldnt move.....My fluid is full, my linkage and driveline are hooked up as well. Why wont she Go???
Old Mar 17, 2009 | 12:13 PM
SpecV44's Avatar
What 6.0 did you swap in? The LS2? LQ4/LQ9? The same transmission you used before? Any mods the trans? Stupid question, but did you check the fluid warm, running, and in Park?
Old Mar 17, 2009 | 12:16 PM
performabuilt's Avatar
LS1Tech Sponsor
Remove a cooler line and start car see if fluid sprays , It it dosent you broke the pump.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 17, 2009 | 12:27 PM
Ok, Ill try the trans cooler thing. Its the LS2 and yes its the same tranny that was in it before (Stock)
......Yep my pump isnt doing its job. Any suggestions on a good one to get?
Old Mar 20, 2009 | 10:25 AM
Could It Possibly Be An Electric Problem?
Old Mar 20, 2009 | 10:33 AM
LS1Tech Sponsor
No theres no electrical issue that will cause a no movment condition.
__________________
Call 888-744-6542
