torque conv fluid...does trans provide via shaft?
Old Mar 21, 2009 | 08:38 AM
Stroker2112's Avatar
Default torque conv fluid...does trans provide via shaft?
I just finished bolting my 4L60E back in and realized I forgot to put fluid in the torque converter. The trans will pump fluid into the converter via the input shaft....right?
Old Mar 21, 2009 | 08:47 AM
NHRAFORMULA00's Avatar
You have to put at least 1 quart in the converter before intallation.Take it back apart or youll be sorry!
Old Mar 21, 2009 | 08:51 AM
I only put in approx 1/5th of a quart.....any one else have an opinion?....
Old Mar 21, 2009 | 08:59 AM
FLT's Avatar
FLT
It is always best to put about 1/2-1 qt in the converter before installing it. The converter will finish filling after you start the vehicle up. Vince
Old Mar 21, 2009 | 09:10 AM
Right, that's already understood. ..the question is will the trans fill up the converter adequately when I only put about 1/5th of a quart in...everything is already bolted up....would like to avoid dropping the trans again if the trans is going to fill the converter...
Old Mar 21, 2009 | 10:05 AM
FLT's Avatar
FLT
Yes the trans will fill the converter.
