problem
Old Mar 22, 2009 | 02:32 AM
mikemunoz's Avatar
Default problem
have i have a 2000 camaro with 22-2800 stall and bolt ons and can power brake it. ok problem is i just put in a torquer 2 cam why a wideband tune and it does not power brake anymore all it does is boggs and on top of that is when i gun it it just boggs and then it kicks. anyone know why, can it be the stall is not big enough
Old Mar 22, 2009 | 08:53 AM
performabuilt's Avatar
LS1Tech Sponsor
its possible not familiar with the powewr band of that cam but the stall ajust be too small and the power starts much higher.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 22, 2009 | 09:03 AM
Circle-D's Avatar
I agree, you just changed the torque curve of the engine and now the converter does not have as much low end power. You need a higher stall converter to take advantage of the new cam.
Chris
Old Mar 22, 2009 | 11:44 AM
TXCAMSS's Avatar
"All Motor 9 Second club member"
I'd bet money that is the problem. A 3800-4000 stall would let the cam come alive. My son ran into the same problem with his Silverado after a cam change. That issue is being corrected with a new Circle D custom billet 258mm converter It's gonna be rolling hard very soon
Old Mar 22, 2009 | 02:21 PM
Yank's Avatar
A converter will take care of this but you might check the cam install to make sure it was not installed in a retarted state as some extra advance might help your bottom end torque loss.
Old Mar 22, 2009 | 02:51 PM
heymoej's Avatar
i had the same cam & a 3200 stahl & then went to a pt4000 & it got much better..........
