4L60E Problems
Old Mar 25, 2009 | 01:31 PM
InsaneDomestics's Avatar
Default 4L60E Problems
I have kinda a dumb question but Will The 4L60E Bolt Straight Up To An LS2 With No Problems? Just wondering because I swapped my LS1 for an LS2 out of an 06 GTO that was a 6-Speed and I havent been able to move my car. I thought it would just bolt up and go no problems but I guess I was wrong. My Tranny isnt pumping so I was wondering if theres a difference in the shafts or anything? Maybe its just coincedence that my Trans Pump went out the same time I did the swap or something I dunno. Any Ideas?
Old Mar 25, 2009 | 05:49 PM
crzytown69's Avatar
not 100% sure but i would say if your converter bolted to the flywheel and you seated the converter in the tranny properly i would say its the pump... try to un hook one of the tranny cooler lines while its running maybe to see if its pushing fluid
Old Mar 25, 2009 | 06:22 PM
Yea I already did that and I got nothing. I was pretty sure everything is the same. I guess I messed up the pump somehow when I installed my LS2.
Old Mar 25, 2009 | 06:31 PM
crzytown69's Avatar
i would say there is a good chance of that did you pull your tranny to the block by the bolts?
Old Mar 25, 2009 | 08:21 PM
muayyadf1's Avatar
65 and 60 share the same housing. If you have the correct bell housing I can say yes it fits.
Old Mar 26, 2009 | 12:01 AM
Yeah There Was Still A Gap About 1/2 Inch (Maybe A Lil More) And I Sucked It Up With The Bolts. Probably Messed Up The Pump Huh?
