4l60E interchangeable??
Old Oct 21, 2003 | 08:35 PM
lm7's Avatar
lm7
Default 4l60E interchangeable??
Can a 4l60E from an LS1 f-body fit a 5.3 or 6.0 block?? Can a truck 4l60E fit an f-body??
Thanks!
Old Oct 22, 2003 | 08:33 AM
A BAD T/A's Avatar
Default Re: 4l60E interchangeable??
Biggest problem is ELECTRONIC! The second is getting the flexplate and converter for the engine you want to put the 4L60E with. It can be done, some are very easy, some not!
Old Oct 22, 2003 | 02:00 PM
Doc's Avatar
Doc
The tail shaft cover on the "truck," version doesn't have the provisions for the torque arm either.
