input shaft seal?
Old Mar 30, 2009 | 06:50 PM
PedaltoMetal's Avatar
Default input shaft seal?
Do rebuild kits normally come with the input shaft seal? I've gone through 3 kits now and none had it. Is it round or square? It looks square but it might be from being compressed in the converter. odd i know
Old Mar 30, 2009 | 06:59 PM
performabuilt's Avatar
LS1Tech Sponsor
Should be round if your talking about the lockup oring , Most kits they are green though have seen them in other colors.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 30, 2009 | 08:39 PM
yeah the lock up oring. It doesn't live a good life in there if it starts out round. Thanks
Old Mar 31, 2009 | 10:27 PM
2002CAMAROSSLS1T56's Avatar
Do you know if the green one and red are the same?
I've seen the green one forever in 4L60 and 4L60E kits, back then it was for the V6 trans only.
Now I always buy the red one from GM and it's slightly different than the green one.
Guess it would work, just wondering if anyone knew for sure. Do you know?
