help?? will a truck Tranny work
Old Apr 7, 2009 | 03:01 PM
cyamaha2007's Avatar
Default help?? will a truck Tranny work
im doing a 5.3 swap into my 95 trans am will the auto transmission from a 2003 5.3 2x4 avalanche work with my 2000 trans am computer and wiring harness. also are the mounts different from the car to truck? do you guys see any problems?
Old Apr 7, 2009 | 04:23 PM
01ssreda4's Avatar
from what i have heard the tailshaft has to be swapped to accept the torque arm mount and the shifting linkage must be swapped also.....dunno about the computer part...
Old Apr 7, 2009 | 07:23 PM
ok do you know if a lt1 4l60e tail shaft fit?
Old Apr 7, 2009 | 09:04 PM
performabuilt's Avatar
LS1Tech Sponsor
The L1-1 tail housing will not fit you will need one from a 98 up f body.
The 2000 pcm will run the 2003 no issues or changes.
You will need to swap the linkage shaft from your old 4l60e to the new one its easy enough a bolt and a clip with the pan off. Because the truck one will be too long.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 7, 2009 | 09:36 PM
ok thanks for the help can i use the shift shaft from a lt1 tranny. im in the middle of a ls1 swap
Old Apr 7, 2009 | 09:43 PM
LS1Tech Sponsor
Yes that you can use
__________________
Call 888-744-6542
Old Apr 7, 2009 | 09:49 PM
thanks man you guys are helpful. do you happen to have a ls1 tailshaft housing that you can sell
