Please Help Shift kit
Old Oct 25, 2003 | 03:14 PM
foff667's Avatar
LS1TECH Sponsor
Default Please Help Shift kit
can you guys tell me how to get this apart accumulator ...im in the midst of doing my kit and theres a spring inside here i need to get out and replace
thanks guys...hopefully ill be chirpen em in a couple more hours
lata
Bill
Old Oct 25, 2003 | 04:08 PM
foff667's Avatar
LS1TECH Sponsor
sorry about the broken link use this instead http://www.geocities.com/foff667/98Camaropg3.html you should have no problems.
lata
Bill
Old Oct 25, 2003 | 04:44 PM
Pete2k_Z28's Avatar
Push the piston down, then pull out the metal rod. Put the rod in far enough to be able to wiggle the piston out buy putting light sideways pressure on the rod, effectivly binding the rod into the piston. GENTLE is the key word here! If that doesn't work, you can carefully pop it out with some compressed air (through the fluid passage on the side).
