DO I need a flexplate??
Old Apr 10, 2009 | 06:38 PM
boilertwinkie's Avatar
Default DO I need a flexplate??
I have a bolt on ls1 camaro and just ordered a yank 4K stall for my 4l60e. Do I need to upgrade the flexplate and what company model should I go with?. Thanks
Old Apr 10, 2009 | 06:50 PM
spaz1's Avatar
I would say no you don't need a new flex plate if your is in good shape. Tci does make one sfi approved...if you want to spend some more money.
Old Apr 11, 2009 | 06:02 PM
anyone running the tci flex plate with the pt4000?
Old Apr 12, 2009 | 02:51 AM
drone's Avatar
dont do it. Your going to have issues with the bolt length.
Old Apr 12, 2009 | 10:40 AM
jarednut4ever's Avatar
Yes I would replace it with a sfi unit. Mine was stock and it cracked. They are really weak especially when you start running 1.6-1.7 60's.
Old Apr 12, 2009 | 11:05 AM
MUSTANGBRKR02's Avatar
If you have the money change it. If not then wait till it breaks. I have run some good times with mine and have over 110k on it works fine.
Old Apr 12, 2009 | 06:52 PM
Slowhawk's Avatar
LS1Tech Sponsor
You just don't use the converter bolts that are short.No big deal,use the stock bolts just cut alittle more than a 1/8" off them.
Old Apr 12, 2009 | 11:45 PM
WHPLASH's Avatar
I bought ARP flexplate bolts at the right length for About $12. No biggy.
Also, Speed Inc sells a SFI approve flexplate for about half the price as the TCI. I have the TCI though.
Old Apr 14, 2009 | 06:50 PM
What bolts are everyone using?
Old Apr 14, 2009 | 07:59 PM
FTICONVERTERS's Avatar
LS1Tech Sponsor
you could compliment your yank with one of our SFI approved billet flexplates.Heres the link. https://ls1tech.com/forums/sponsor-s...lates-fti.html
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Apr 14, 2009 | 08:06 PM
01trans am's Avatar
I have a 4000ss and didnt replace the flywheel. Some say you need to others dont. If its mess up when you drop the transmission then replace.
Just to give you an idea of how strong the stock flywheel is. I broke one converter bolt in half and it was stuck behind the flywheel for more than one day and bent another bolt and my flywheel is still perfect for now
