TCI 6 sp auto
Old Apr 15, 2009 | 06:57 AM
forcd ind's Avatar
Default TCI 6 sp auto
i thought this was covered, but couldnt find it-anyway, i was looking at an add for the TCI 6 sp auto, they use a 4l80e case, and somehow add 2 extra gears-starts out as a lower first gear-i would imagine its priority to their controller, got to be an expensive setup-just curious how they got the extra gearing in the case
Old Apr 15, 2009 | 07:58 AM
rsm425's Avatar
Here's the thread on it. The extra gearing is done with valve body changes and TCU changes.
https://ls1tech.com/forums/automatic...peed-auto.html
http://www.tciauto.com/WhatsNew/
Old Apr 15, 2009 | 09:01 AM
slow67's Avatar
Gingervitis Addict
They basically do this: 1st, 1st and OD engaged, 2nd, 2nd and OD engaged, 3rd, then OD. The lower first gear is accomplished by a different planetary setup, available for any Th400/4L80E. The 6 speed is all in the valvebody/electronics.
