crazy flexplate question
Old Apr 15, 2009 | 08:06 PM
mlt73's Avatar
Default crazy flexplate question
i pulled the tranny for a converter swap and noticed that the flexplate was cracked at all 3 converter holes. then upon further inspection i noticed it was warped or bent at the same locations (when looking across the teeth, around the flex plate). when looking at the back of the engine, the converter was dished toward me. is that right? the car only has 44000, 18000 which i put on, and i really don't think anyone has had the tranny out, but who knows. how do i find out what flexplate is right? also, the car started fine every time. thanks in advance for the input, mike
Old Apr 17, 2009 | 07:27 AM
Intercooler2's Avatar
I have a perfect 02 stocker in the for sale section $20 if you are interested. Pics of it there too.
Old Apr 17, 2009 | 08:14 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Look the ones that Speed Inc, TCI and FTI Converters offer. They are all SFI approved, FYI
Old Apr 21, 2009 | 07:56 PM
boola1341's Avatar
Did you get any vibrations with that broken/warped flexplate? I have a vibration problem which started after I installed my trans, stall and cat flexplate. I'm told it may be a warped flexplate.
