what kind of flare?
Old Apr 25, 2009 | 07:19 AM
ricknbird350's Avatar
Default what kind of flare?
whats kind of flare is on the 4l60e transmission cooling lines going into the transmission? is it a bubble flare?
Old Apr 25, 2009 | 07:54 AM
FLT's Avatar
FLT
Not sure what they call it but if there is an issue I have always suggested just replacing the whole line with a new oem one. Or you can make your own lines out of 5/16 steel ones and change the fittings in the trans to the proper ones. Another option is to go to braided lines with AN fittings. Vince
Old Apr 25, 2009 | 05:50 PM
2002CAMAROSSLS1T56's Avatar
The older lines that screwed into the brass adapters on the trans are 5/16" inverted flare.
Old May 3, 2009 | 07:10 AM
my 95 has a 60 e transmission, the lines are double flare. i have a 98 that i was making to lines on and after i made the line i realized its not a double flare. i didnt want to drop the trans down just to see what flare it is.
Old May 3, 2009 | 12:38 PM
A '98 is going to have quick connect lines, not flares, unless you change the fitting in the trans.
Old May 17, 2009 | 07:23 PM
there is no fitting all i see on mine is just the threads on the transmission. i guess im missing fittings that go into the transmission? anyone have these fittings?
