broke flywheel ??!!
Old Oct 29, 2003 | 06:18 PM
98sspullin'em's Avatar
Default broke flywheel ??!!
i was driving my car and i heard this nocking sound, then thought it was the enginge, but it does it off and on so i think its the fly wheel?? could that be it???
Old Oct 30, 2003 | 12:23 AM
Stun'nSun'nZ28's Avatar
Default Probably
A Friend of mine had the same problem... Sound would be there for awhile & then everything would be okay... His was a bad flywheel , just as you have surmised !!! Good Luck
Gary
Old Oct 30, 2003 | 02:44 AM
thanks, ill need it, i hope thats it!!
Old Oct 30, 2003 | 09:57 AM
Kevin Winstead's Avatar
You should double check your converter bolts too. They may be loose.
Kevin
