4L60E Hose Diagram
Old Apr 26, 2009 | 11:41 AM
7th Darkness's Avatar
Question 4L60E Hose Diagram
I need a hose diagram to check to make sure my lines are going in the right place.
1. The top & bottom lines coming out of the trans... which one is in and which one is out?
2. Whats the in and out on the cooler, the bottom or the top?
Should the top on the cooler go to the top line on the trans or the bottom line?
Also, the vent tube on the top of the trans..what is the proper position for this line and if a lot of fluid is coming out does this mean a plugged line?
Old Apr 27, 2009 | 08:56 AM
Any body?
Old Apr 27, 2009 | 03:47 PM
Badazz 97 TA's Avatar
the bottom cooler line from the trans goes to the bottom passenger side of the radiator. The line on the driver side of the radiator goes back into the trans which is the top line.
Old Apr 27, 2009 | 11:59 PM
Both my lines go to the passenger side. One on the top and one on the bottom
Old May 3, 2009 | 04:57 PM
GA95DCMSS's Avatar
1. Top trans fitting= return from cooler
Bottom fitting= supply to cooler/radiator
Old May 3, 2009 | 05:24 PM
tording99Z28's Avatar
The vent tube is just to vent the transmission of air. You should not have any fluid coming out of this tube, if you do it is probably way too full of fluid. It doesn't matter what position it is in.
Old May 3, 2009 | 09:25 PM
2002CAMAROSSLS1T56's Avatar
Top trans line to top radiator line.
Bottom trans line to bottom radiator line.
Position the vent tube to blow fluid away from anything hot, like the exhaust.
