Quick Question...
Old Apr 26, 2009 | 11:41 PM
tatasta's Avatar
Default Quick Question...
I am looking to upgrade to a 4L80E. Will the 80E out of a 2004 or 2005 pickup work? Does it matter if the truck was a 4X4 or not, other than getting the correct tail shaft housing?
Thanks!!
Old Apr 27, 2009 | 01:01 AM
performabuilt's Avatar
LS1Tech Sponsor
The trans will work from those years however it will need to be a 2wd or you will need to tear down the trans and replace the output shaft and make mod for lube. 4WD will not work without this.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 28, 2009 | 02:04 PM
tatasta's Avatar
Thank you. Figured the deal was too good to be true.
Oh well, I'll keep searching.
