Update
Well guys I finally was able to get under the car. Been so busy since I posted this thread, I really never had a chance or was able to get under there till now. As I examined the trans pan you can see trans fluid all over it. The thing is it's mainly on the bottom and doesn't seem like it's leaking over the edges were it's bolted up to. It also seems that, not sure what it's called but, i'll take a shot at it, cross member? Which is directly behind the trans pan crossing the rest of the trans as a support. Seems to be covered with what i'm thinking is the trans fluid? I am limited to a floor jack so I really can't get a better look or if it's even possible to get a better look. Also, theres a wiring harness under there that has it all over it also not sure if that matters? It seems to drip a lil bit after I get done driving her not sure if it's right after or later? I haven't driven her much because of the drip. When I do it's to work and back when I have to, which is about 14 miles one way. Please, if there is anyone who might think or know as to what it might be let me know. It would be grately appreciated. Thanks
