Question TH350- Brake slow to engage
Old May 3, 2009 | 11:27 AM
rickou812's Avatar
Default Question TH350- Brake slow to engage
I have a freshly built TH350 and the brake seems a little slow to engage. When I mash the transbrake button and release the foot brake, it will want to move about 1 foot before it locks.
Is this normal? Am I just releasing my foot brake to quickly or is this a slow engagement?
It is a JW brake fwiw. Everything else is perfect..
Thanks
Old May 4, 2009 | 10:27 AM
Reboot's Avatar
I really want to know as well. My Rossler TH350 does the same thing. Sometimes it rolls 2 feet or more. I haven't tried the TB at the track yet because of this. When the car hooks off of the footbrake it 60's in the mid 1.3's and I would like to improve on that.
I'm considering wiring the linelock on a toggle switch to run with the TB.
Old May 4, 2009 | 11:08 AM
rickou812's Avatar
I was also thinking the same thing..
Old May 4, 2009 | 10:55 PM
WE TODD DID's Avatar
How do you have the solenoid wired? Is it through a relay, or is it a direct battery source? The solenoid draws a bit of amperage, so it takes some juice to apply it. I've had to run direct battery voltage to them before.
Old May 5, 2009 | 04:48 AM
rickou812's Avatar
Mine is wired direct..
Old May 5, 2009 | 05:50 PM
Does it delay in reverse? There may be low line pressure in the reverse circuit, or excess clutch clearance.
Old May 5, 2009 | 06:04 PM
rickou812's Avatar
No noted delay in reverse when shifted into reverse. Also I do not have to engage transbrake for reverse like some do..
Old May 5, 2009 | 06:13 PM
Reboot's Avatar
I have to hit my TB button for reverse and mine takes 5-10 seconds to engage.
Old May 6, 2009 | 08:14 PM
FTICONVERTERS's Avatar
LS1Tech Sponsor
You need to check the Transbrake valve throw in the unit. This can only be done by pulling the valve body. A line pressure check would not hurt either.On 350's and 400's sometime you have to adjust the throw on the valve. Also you need to make sure that it fits the bore correctly.(not hanging) Make sure that there isn't 2 orings on the solenoid.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old May 6, 2009 | 08:40 PM
rickou812's Avatar
Greg
I have somewhat checked it. The JW instructions say to check the spring to make sure it is not to long by ensuring that the plate on the rear of the solenoid will completely bottom out, which it seems to do.
I have not checked pressure yet, (don't have gauge..yet) but will. Which port do you recommend to use for checking pressure?
Thanks
Old May 23, 2009 | 10:13 AM
Reboot's Avatar
Update: I was having the same issues as posted above. I direct wired the TB power to the battery with a high grade 14 gauge wire. It works flawless now.
I made 4 passes last night off the brake with no roll.
