Thinking of going TH400
Old May 3, 2009 | 08:46 PM
01FbTaWs6's Avatar
Default Thinking of going TH400
OK guys. Ive currently got a T56 in my car and am thinking of swapping to a TH400. My question is, who here is running them, with what stall and what rear gear, tire size, and what is your RPM at lets say 75 mph? I know they dont have any lockup, and that is my only worry. Ive currently got a heads/cam car (specs in sig) with a 4.10 gear, and plan to keep with this gear, and go to a 28 tall tire. Please, any info or recommendations are appreciated!!
Old May 3, 2009 | 09:16 PM
2002CAMAROSSLS1T56's Avatar
At 75 MPH you'll be at 3899 RPM with 4.10's, 28" tires.
Rear gear x 355 x MPH / tire diameter = RPM
(FYI- 355 is for a high stall converter and unlocked, a lot of calculations use 336 but thats more for manual transmissions, locked up converters or stock low stall.) And for overdrives it's rear gear x OD ratio x 355 x mph / tire = rpm.
Old May 3, 2009 | 09:18 PM
01FbTaWs6's Avatar
holy bajesus!!! No way in hell that right there would work.... Im thinking of going like a 3800 stall.
Old May 3, 2009 | 09:39 PM
performabuilt's Avatar
LS1Tech Sponsor
Yes I think I spoke with you. If this car does anything other than race I would really consider either a 4L60E if under 600-700 hp if over and since your swapping anyway a 4l80e might also be a consideration.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 4, 2009 | 02:00 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I'm running a TH350 with 4.11s and a 27" tire. I'm at 3300 RPM at 65 mph
Old Jun 6, 2009 | 12:19 AM
Raven02TA's Avatar
same here with my th400. but on 28" tire.... i think at 70 MPH im at 3500
Old Jun 7, 2009 | 08:09 AM
98Camarod's Avatar
That's not too shabby
Old Jun 7, 2009 | 08:55 AM
tals7's Avatar
Exclamation tals7
400th great for drag car but if drive on street you should look into 4l80/4l85e swap.the swap is easy a is money well spent .they are also just as strong as th400 but way better on street.
 Michael S. Palmer
Old Jun 7, 2009 | 09:58 AM
gator's 99TA's Avatar
i have a TH400, 325 radial (28") and 373 gear. i am at 3500 rpms at 70 mph and its pretty comfortable with a quiet exhaust. i never do more than 70 mph other than at the track or i get a hair up my *** and feel like hammering it.
Old Jun 7, 2009 | 11:32 AM
99Z28LS1's Avatar
I agree with the above, If you're going to drive it everyday, the 4L80 would be the way to go.
I'm moving from a T56 to a th400, but my car will not be daily driven. I already have the th400, it has a 3200 precision stall in it. The car will be on a 28'' tire with 2.75's in the back. I'm going with a low gear because I will be running against bikes and what not on the highway.
Old Jun 23, 2009 | 11:07 PM
y2kfrc's Avatar
Nice building a bike killer! pm me when you wanna test it out
Old Jun 24, 2009 | 02:37 AM
CarsandWomen's Avatar
do keep in mind also that th400's are known for useing a lot power to turn themselves, on average 150 to 200 horspower.
an aquaintance had a 400 with a 3200 stall in an 04 gto with a 408, he drove it daily for a while, loud exhaust and all. after not long he hated it and just recently switched back to a t56. he was at roughtly 3000rpms at 65mph
Old Jun 24, 2009 | 08:56 AM
built408's Avatar
I don't think a 400 eates 150-200 hp.
Old Jun 24, 2009 | 12:11 PM
allbaugh_04's Avatar
I don't think a th400 would be all that bad, just don't put gears like 4.10s in your rear and you should be ok.
Old Jun 24, 2009 | 12:45 PM
tee-boy's Avatar
TH400 for racing. No other reason to do it, unless you just want to save a bunch of money by not going 4l80e.
Plenty of TH400's in the junkyard.
Old Jun 25, 2009 | 12:14 AM
every one ive ever seen engine dyno and chassis dyno numbers for did. Thats allowing for rear end accesories. Its that high IMO. Its been my experiance they eat more power the more built up they become.
everything ive heard is they suck more power than most. really the only way to find out would be an engine dyno with a couple different trans behind it. my .2.
Built408, whats your estimate for their power consumption? Are you aware of their reputation for it? Not trying to be a dick, im looking for your honest opinion.
Old Jun 25, 2009 | 08:58 AM
Who cares, the gearing is better than the 4L60E anyways. You might not put out more hp, but if track times are what matters, then the TH400 is the way to go.
