Vss 4l80e swap
Old May 7, 2009 | 08:42 PM
js2fst's Avatar
Default Vss 4l80e swap
Which wire is the vss i need the signal wire doing a tci controler on a 4l80e from a t56
Old May 13, 2009 | 09:57 PM
js2fst's Avatar
help??
Old May 13, 2009 | 11:16 PM
Kevin Winstead's Avatar
The TCI controller has both a TISS and a TOSS (trans Input speed sensor and trans output speed sensor). The TISS is the transmission Input Speed Sensor...the TOSS is the Transmission Output Speed Sensor. Both are on the driver's side of the case. The TISS is towards the front...the TOSS is towards the rear.
Old Aug 8, 2009 | 10:06 PM
tals7's Avatar
Smile
just plug your speedo connector into the toss/out put speed sensor which is the rear one and splice the tci toss wires into them.
