Th400 Conversion
Old May 11, 2009 | 10:56 PM
Next level's Avatar
Default Th400 Conversion
im working on getting a th400 conversion in my 94 formula. I am alittle confused on what i need tho.
I got a Th400 from mild to wild in kenosha brand new
i got the converter
i got the M6 center console
I am getting the cross member from BMR but im lost with all the computer compontes, is there anything else i need to get for the computer to delete the 4L60E BS ?
Old May 11, 2009 | 10:57 PM
Next level's Avatar
and since im on the topic im worried about drive abilty on the roads. good or horrible ?
Old May 12, 2009 | 01:51 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Depends on what your definition of driveability is
Old May 12, 2009 | 07:00 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
What you need is an FTI Transbrake 400 w/ a competition torque converter. We have ultrabells, filler tubes and the electric speedos in stock for this conversion.Call or pm for details on package pricing.
Greg
1-866-726-8358
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old May 12, 2009 | 08:54 AM
Next level's Avatar
able to drive around town not so much highway or anything but to local shows and enjoy the car while out on the road.
Old May 12, 2009 | 09:07 AM
Z28/2002's Avatar
I drive my CETA around town when the weather permits and I also drive it to the track and it has a TH350 with 4.11s. If you don't care about the gas mileage or the RPMs you'll turn then I would go for it. It will be a completely different animal
Old May 12, 2009 | 05:04 PM
Next level's Avatar
thats kinda what i needed to know. thanks.
Old May 13, 2009 | 09:53 AM
'99CaMaRoSs's Avatar
check out gearvendors.com
Old May 13, 2009 | 10:34 AM
pddye's Avatar
I've got one in mine. Its not to bad at all but just be ready to get around 11 mpg. Thats what I get in mine with a 3000 converter, 3.73's, on a 28" tires. Its not bad for around town and a weekend cruiser.
Old May 13, 2009 | 11:03 AM
Next level's Avatar
i guess my biggest concern is with a TH400. Once you get to 3rd gear and without a OD it just keeps redlining. So on the track doesnt it hit redline before you hit the 1320 mark or close to ?
I mean when i had my 4L60E i was going into 4th gear pretty quickly with my 396 with 3:73 on a 28" tire.
Also around town even you can really go over what 60mph ?
i can careless about noise and gas mileage. Im really concerned about drive abilty. I have been told that TH400 is the way to go, well 5 years hearing that i finally am but very concered about over revving in the 3rd.
Old May 13, 2009 | 02:42 PM
pddye's Avatar
I think at 65 mph on the interstate i'm somewhere around the 3200 mark
Old May 13, 2009 | 02:45 PM
Next level's Avatar
ya im thinking of going a different route.
https://ls1tech.com/forums/midwest-c...l#post11592480
Old May 13, 2009 | 03:54 PM
Z28/2002's Avatar
With the setup I have (post 6), I turn 3300 at 65.
What is a redline I turn my car to 7K on the upshifts but have no idea what it's turning through the traps
Old May 13, 2009 | 04:01 PM
GreatWhiteZ28's Avatar
so what all is needed for the swap?? but I'm going to be using an LSX under the hood..
I know fo the Trans Cross member, and as well would like to know about the computer end of the swap....
Old May 13, 2009 | 04:31 PM
pddye's Avatar
The swap is easy. Just get a 6 speed style crossmember, strange driveshaft, and a new flexplate and your good to go. I like my th400. I don't know if i'm keeping it (the car) or not but in a auto f-body I wouldn't do it any other way unless you went to a 4l80e.
