Trans Mount?
Old Nov 3, 2003 | 01:14 AM
TurboJohn's Avatar
Default Trans Mount?
What mount do you guys use to replace a broken mount? I have a ES poly mount from another car but I've heard about it being bad for our cars. Is a Pro-thane mount any better? Or should I just use a 1LE mount and does anyone know the part number for it.
Old Nov 3, 2003 | 02:01 AM
Pete2k_Z28's Avatar
1LE is a geat mount. I wouldn't run poly unless you have poly motor mounts. The 1LE is stronger and stiffer than stock. Best part is they're only $20 or so from SLP (well, they were when I got mine). The stud that goes through the crossmember is a different size, so you will need two nuts, a washer, a lockwasher, and some loctite would help as well. All another $5 in materials, including the Loctite.
Sorry but I don't have the part # handy
Old Nov 3, 2003 | 07:30 AM
99-LS1-SS's Avatar
STF Veteran
I replaced my tranny mount with a poly mount and now I can feel EVERY vibration in the drive train. If I did it again I would get a 1LE mount.
Old Nov 3, 2003 | 02:00 PM
Jeffs99SS's Avatar
A friend of mine relaced his stock mount with a Energy Suspension poly mount, and it vibrates like crazy. Definately would not be my first choice.
Jeff
Old Nov 3, 2003 | 03:04 PM
foff667's Avatar
LS1TECH Sponsor
i dont really have any problems with my ES mount.
lata
Bill
Old Nov 4, 2003 | 10:50 AM
TurboJohn's Avatar
lata
Bill
Did you remove the "nubs" before using you ES mount? Are the nubs where the mount touches the trans.?
Old Nov 4, 2003 | 12:36 PM
foff667's Avatar
LS1TECH Sponsor
nope..i just installed it like ive installed all my tranny mounts...i have little to no vibration thats noticable.
lata
bill
