th400 shifting problems
Old May 13, 2009 | 07:56 AM
ls1foxcoupe's Avatar
Default th400 shifting problems
I have a new trans and I have a problem going into high gear.
When I shift to high it does nothing, but if I go to neutral and back to drive quick it will shift.
Any help will be appreciated.
Thanks,
Justen
Old May 13, 2009 | 08:15 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Try to adjust the shifter linkage
Old May 13, 2009 | 05:25 PM
I have adjusted it several times in park, 1st gear, and drive. No change.
