Dipstick Tube
Old May 24, 2009 | 01:25 PM
camaro crazy's Avatar
Thumbs down Dipstick Tube
Guys I need help I got a new dipstick tube how do I get it back in. My old one was bent and twisted so I cant use as a guide.
Old May 24, 2009 | 01:43 PM
Badazz 97 TA's Avatar
it helps to have the trans not bolted to the engine. allows more room to work
first put a little trans fluid to lube the rubber grommet up. stick the rubber piece half way in the hole and then put the tube in and push hard. it also helps to put a wrench on the top of the flared thing and hammer the tube lightly and that usually sets it in place all the way.
i hate putting that tube in
Old May 24, 2009 | 02:29 PM
FLT's Avatar
FLT
Hopefully you will be good for a while!
Old May 25, 2009 | 06:28 PM
I wish I had the trans loose but I don't let's hope for the best
Old May 25, 2009 | 06:45 PM
SINISTER's Avatar
good luck..i couldent get it with out the trans unbolted
i order a flexable one from lockar had it in within 10 min
Old May 26, 2009 | 08:11 PM
where do you order one from is it a company local or what thanks for help
