Installing Yank, have question about flywheel????
Old Nov 6, 2003 | 10:42 AM
WS6snake-eater's Avatar
Question Installing Yank, have question about flywheel????
Hey guys I'm right in the middle of my trans re-build (4l60E) and I am installing a PY3600E. The converter has 6 holes and came with 6 bolts, but my flywheel only has provisions for 3 bolts. Has any one else ran into this? How did you go about the intall? Drill 3 more holes? Just use three bolts?...Any help would be appreciated. Thanks!!
Old Nov 6, 2003 | 11:07 AM
FEAR THE LS1's Avatar
You will be fine using only 3 holes. My Yank SS4000E can with 6 flanges on the converter I always used only 3.
If you want to you can remove the fly wheel and bolt it to the converter and drill the other 3 holes. For your setup and using that stock flexplate it won't make any difference.
Lee
Old Nov 6, 2003 | 11:10 AM
alrighty then appreciate it!
Old Nov 6, 2003 | 07:17 PM
Ragtop 99's Avatar
Not a big deal, but I'd drill the holes if you can.
