PRNDL switch pigtail part number
Old May 31, 2009 | 05:11 PM
SINISTER's Avatar
Default PRNDL switch pigtail part number
does anyone know the part number for the pigtail for the PRNDL switch located on the shifter of a 99-02 4l60e f body shifter
i just did m6-a4 swap and the shifter i got does not have thise pigtail..
need to wire up so the computer see's what gear its in and the park netrail saftey switch and the reverse lights work..
anyone have a picture of one??
a part number would be grand also
Old Sep 1, 2009 | 12:17 AM
Avengeance's Avatar
up to the top....
Anyone have the part #?
Old Sep 1, 2009 | 10:22 AM
FLT's Avatar
FLT
There's actually two of them, the 7 pin connector number is 15305887.
The four pin connector number is 88987185.
If you need the switch the number is 24229422.
You should be able to order these from your local GM dealer.
Old Sep 1, 2009 | 07:24 PM
Avengeance's Avatar
Found it... the actual pigtail to the shifter is GM PN: 12117379 or AC Delco PT512 .
