Slip Yoke Issue
Old Jun 1, 2009 | 09:54 PM
tee-boy's Avatar
Default Slip Yoke Issue
Slip yoke supposed to slide all the way into the transmission output?
I had a driveshaft built according to measurement for my 400 trans. When the rear universal joint is bolted to the pinion flange, the slip yoke could actually slide in another 2 inches into the trans. The builder tells me this is normal. Could someone help me out here.
Old Jun 3, 2009 | 02:21 PM
tee-boy's Avatar
so, what do ya'll know? Is this going to ruin my new transmission?
Old Jun 5, 2009 | 07:58 PM
oldtimelt1's Avatar
Sounds normal to me, it needs to be able to move into and out of the trans for the diff. to move and not bottom out inside the trans.
I ran one that the driveshaft was too long and it was hard to get the u-joint in the yoke. I'd say if you have 2" in the trans past the seal it is OK.
