Small problem w/ TCI 3800
Old Nov 10, 2003 | 09:12 PM
BLK02WS6's Avatar
Originally Posted by Jpr5690
hey if you get time can you answer my question that i asked eariler. im really intrested in hearing your responce being im looking at doing this proiject in the future also when everything is on the road some feedback would be appriciated if its not a big inconvience to you
I don't know all the details that went into my tranny. I had it built by a local guy that had done several others in my F-body club. I know billet servos, heavy sun ring, new planetarys, Raybestoes clutches, kevlar bands, Transgo shift kit and vacuum modulation. That is about all I know.
I would say either find someone who has a good reputation locally (for performance trannys, not stock rebuild) or check out one of the posts on here about getting on shipped. One thing for sure, don't think a stock rebuild is gonna hold up for long!
Hope that helps! Let me know if I can answer any more questions.
Old Nov 10, 2003 | 09:27 PM
onebadz's Avatar
Ditto
Old Nov 11, 2003 | 07:52 AM
Kevin Winstead's Avatar
You should only use the antisieze on the pilot that goes into your crankshaft. You can use loctite on the bolts.
Kevin
Old Nov 11, 2003 | 08:23 AM
onebadz's Avatar
Thanks for the info Kevin
Old Nov 11, 2003 | 01:22 PM
BLK02WS6's Avatar
Kevin
They did loctite my bolts/nuts. Drilling the converter threads and using the bolts/nuts is gonna be OK, right Kevin? I hope so, cause one of your tech guys told me to have the shop go ahead and do it.
By the way - the 3800 stall seems to be a bit too much for a daily driven car. I got it from one of your dealers and I told them I drive 25 miles each way every day - in and out of traffic. They recommended the 3800 over the 3500, but I'm thinking I made a mistake! It takes 2000 to 2500 RPM to roll the car away from a light. The gas mileage around town had to drop to 10 mpg or so! Highway is fine because of the lockup.
I might have to replace this thing - I'm gonna give it a week or two to see if I get used to it. Some say I will. I don't know.
Old Nov 11, 2003 | 01:30 PM
I've never advised a customer to use a nut and bolt, but if you're going to do this then be sure to use some 3/8" Grade 8 bolts and nuts and you'll be fine. I've done this more times than I care to admit. Heck GM used a nut and bolt for years on OE converters. The first time I tried it, I was working on a 454 Chevelle and we had forgot to drill the flexplate holes out for the 7/16" converter bolts. I didn't notice it until we had the TH400 in there and bolted up. The 3/8" bolts held up fine. You do some strange things when you've got to go to the track. All that being said, I'd prefer that you sent the converter back to me and let me redrill and retap it.
You'll probably get use to the looseness of the converter, but if you don't, we can always tighten it up to a 3500 stall for you.
Kevin
Old Nov 11, 2003 | 01:54 PM
JohnPayne's Avatar
The converter we have gotten in the past have used stock bolts, I always run a tap through them just to check them out (just a personal choice), they have paint and all in the threads and I had rather make sure the bolts start on the bench rather than in the car.
The comment about bolts being a crappy way to do the install, whats up with that? ARP makes bolts for a converter with self locking nuts and all, I have used bolts a lot of times with out any problems.
Old Nov 11, 2003 | 01:59 PM
2xLS1's Avatar
That's going to be real fun getting to the back side of the converter to get a nut started through the starter hole. This isn't a TH350 that you can remove a dust cover on. I sure hope you get those holes drilled dead on center. I can't believe you're giving this advice and it's even harder to believe TCI doesn't tap the threads metric. Everything on these cars is metric. Can't find metric T/C bolts??? Go to any GM dealer and ask for part # 1261968. M10x1.5 hex head T/C bolts with loctite alerady on the threads. And good luck ever trying to resell that converter with the holes drilled out.
Old Nov 12, 2003 | 06:36 AM
2xLS1,
Think Positive
BLK02WS6,
If you ever decide to sell your converter, just send it to me first, I'll repair it for you.
Kevin
Old Nov 12, 2003 | 03:59 PM
BLK02WS6's Avatar
2xLS1,
Think Positive
BLK02WS6,
Kevin
2xLS1 - it wasn't really a big deal to get the nuts on and tighten them up. And yes, the holes were drilled on a press so they were centered.
The reason we went this route was because TCI said it was alright to do it, and we didn't have time to send the converter back. They probably could have tapped them out to bigger sized holes, but thought it easier to just drill and use nuts.
It worked fine - no vibrations or shudders or any other problems!
Kevin, I will post over on my other TCI 3800 thread about my latest findings on performance, but thanks for the offer of fixing the bolt holes and tightening up the stall.
Old Nov 13, 2003 | 09:22 AM
JohnPayne's Avatar
Good deal, I have used bolts before also and had no problems. Glad you got it going.
