Lost R,2,4 gears
Old Jun 6, 2009 | 09:47 PM
jaycenk's Avatar
Default Lost R,2,4 gears
I have had a lot of problems with this Monster preformance built 4l60e that I put in the car back in november. It is supposed to be built to handle 500 flywheel hp.
The car is a 97 Z-28 with stock 3.23 gears and I currently have a deep pan and a B&M cooler running valvaline trans fluid in the car. Engine is stock LT1 with LT headers, EGR delete, SLP CAI, BBk 52mm TB, No cats, SLP loud mouth cat back
Today I was pulling out on to a US19 and I got on it and it tried to shift to second gear and dropped back in to first. I was all over the rev limmiter and as soon as I got out of it it shifted to third gear and would not go into forth.
I have now learned that I start in first gear from a stop and no matter how light I touch the gas it will wind 1st out to about 4k rpms and then shift to 3rd gear and it seems I have lockup in 3rd but no forth gear no matter how fast I go. I also don't have reverse. I only have 1st and 3rd.
This trans has given me trouble since day one but I have gone round and round with the builder and they keep saying it's my PCM or wire harness. It wasn't but the problems went away for a while. Keep in mind this is the 3rd different problem I have had now. It is still under warrenty but I need some ammo to go to the gun fight with them and see if I can get it replaced.
The company is eatmyshift.com or as they call thier transmissions monster. Thanks guys
Old Jun 7, 2009 | 05:42 AM
FLT's Avatar
FLT
Did you loose 2nd, 4th and reverse all at the same time. If so I would bet that you have an issue with a broken sunshell in the transmission. Do you know if they advertise that they use the beast sunshell? The factory shell was known for this issue and I have only seen this issue with the beast a couple of times. Vince
Old Jun 7, 2009 | 06:01 AM
jaycenk's Avatar
yes I lost them all at the same time and no they didn't advertise useing the beast
Old Jun 7, 2009 | 10:05 AM
performabuilt's Avatar
LS1Tech Sponsor
As Vince mentioned its likley the sunshell has stripped which is a common problem even in stock aplications. When they fix it this time tell them to use the beast shell.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 8, 2009 | 03:34 PM
jaycenk's Avatar
k thanks guys. I have to let you know what they intend to do. I should have just gone with the preformabuilt like I originaly planed but I let someone talk me into this "monster".
