determining stall speed
Old Jun 8, 2009 | 05:21 PM
Lt14mla's Avatar
Default determining stall speed
Can anyone go into detail about how to determine stall speed without removing the stall itself? I've read a few suggestions, but most are unclear. I understand there is no real accurate way, but im just looking for an idea of what i got. I think there is an aftermarket stall in the car.
Old Jun 8, 2009 | 10:08 PM
Lone Warrior's Avatar
from a roll, say about 20ish mph in 3rd or 4th gear mat it. this will give you about the best reading, BUT this will not work if the trans shifts
Old Jun 9, 2009 | 08:33 AM
Circle-D's Avatar
Lone warrior has a good suggestion, but that is tough with street tires. If you can force it in 3rd though, it will work. The true test is with a trans-break. The second best is a data logger at the track. You look for the first MPH reading and then see what RPM is.
What can you footbrake the current stall to?
Chris
Old Jun 9, 2009 | 05:41 PM
Lt14mla's Avatar
ive never tried to footbrake it because i dont drag race, so i really never had the need.
Old Jun 9, 2009 | 05:44 PM
FTICONVERTERS's Avatar
LS1Tech Sponsor
Unplug your transmission as it will force third gear starts with max line.Mash the brakes and deck it. See what it goes to. Then plug it back in and clear the solenoid codes.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Jun 9, 2009 | 05:55 PM
Lt14mla's Avatar
thanks for all the help guys!
Old Jun 12, 2009 | 03:25 AM
Bersaglieri's Avatar
Work with a 4L80e FMVB? Just punch it in 3rd from a stop huh? I'll have to try this...right now, sorry neighbors
-Dustin-
