my gear, with TH350?
so I’m going from a 4l60e to a TH350, and the question is how bad will my rpm's be with 4.10 gears? Now with the 4.10s and the 4l60e now cruising on the highway its at about 2300 rpm's at around 55... I’m just wondering how bad its going to be now, with the TH350? I’m going to putt a smaller gear in but its going to take 2 or 3 weeks before i can do so... i did not mind my old set up, so I’m also wondering what gears would yall changing to?
Question
What gear set up should i change to?
And how bad are my rpm's going to be until i change my rear gear ratio? im sure im deff not going to be able to ride on the freeway..
