Tranny only leaks when I hammer the car??
My tranny only leaks when I hammer on my car, If i just drive normal no drip at all.Just wondering what it might be, the obv answer will be don't hammer on it! lol Just looking for a few pointers and info. Thanks in advance
Check that it not overfull or the vent tube has become blocked . Also verify exactly where the fluid is coming from will help solve the issue also.
__________________
Whatever it is, it will continue to get worse, since line pressure increases when you hammer on it, fluid is getting through a small hole/crack/ect. Well, that leak will continue to grow until fixed. Just keep checking your fluid level and you should be OK until you hunt that sucker down. I had fluid leaking from my output shaft, turned out to be a rear seal, easy fix so check that. Also, have you installed a transmission cooler?
no cooler yet, once I get my stall I will get tranny cooler. My car hasn't leaked in days. If I stay out of it I mean hammering it no leaks, only after I went to the track did it leak???
