Must the trans be pulled to install a shift kit?
Old Jul 1, 2009 | 10:37 PM
Gatsby's Avatar
Default Must the trans be pulled to install a shift kit?
Hi all,
I've searched hi and low on this forum and others and I hear mixed results about whether or not the transmission has to be pulled (4l60e in a '99 TA) to install a transgo HD2 shift kit.
So if anyone has done this mod, could you tell me what is involved aside from the valvebody work?
I'd like to do a cooler, then shift kit, then TC, but I'd like to do them in three stages. If i have to pull the tranny I'll wait until I can afford it at once and do it altogether.
Thank you!
Old Jul 1, 2009 | 10:49 PM
PedaltoMetal's Avatar
Yes, you must remove the trans to install the hi-rev springs. Most people it seems skip on that part. Other than the 2-4 servo, all the work is in the pan.
Old Jul 1, 2009 | 11:03 PM
Gatsby's Avatar
So is it dangerous to not do that part then and there? Or can I wait until I do the TC to put those parts in?
Old Jul 2, 2009 | 07:28 AM
Theres no problem leaving them out till it's time for a rebuild.
Old Jul 6, 2009 | 02:07 AM
RevGTO's Avatar
Pontiacerator
Wait until you have your TC installed and when the tranny is out, then do the full HD-2 install. This is the pathway to maximum happiness.
Old Jul 6, 2009 | 03:12 PM
2002CAMAROSSLS1T56's Avatar
I'd also upgrade the 3-4 clutches while it's apart and usually put in an upgraded sunshell.
Old Jul 6, 2009 | 05:40 PM
01ssreda4's Avatar
Id just tune for firmer shifts and say **** the hd-2 until you are ready to buid the trans up.
Old Jul 6, 2009 | 05:57 PM
hevymetalg's Avatar
na just do it i did and its fun too! save the other parts of the kit for the rebuild thants what im doing.
Old Jul 6, 2009 | 08:18 PM
Read over the instructions and decide if it's right for you.
Attached Thumbnails Must the trans be pulled to install a shift kit?-image.jpg   Must the trans be pulled to install a shift kit?-image-2-.jpg   Must the trans be pulled to install a shift kit?-image-3-.jpg   Must the trans be pulled to install a shift kit?-image-4-.jpg   Must the trans be pulled to install a shift kit?-image-5-.jpg
Old Jul 6, 2009 | 08:19 PM
part 2
Attached Thumbnails Must the trans be pulled to install a shift kit?-image-6-.jpg   Must the trans be pulled to install a shift kit?-image-7-.jpg   Must the trans be pulled to install a shift kit?-image-8-.jpg   Must the trans be pulled to install a shift kit?-image-9-.jpg   Must the trans be pulled to install a shift kit?-image-10-.jpg
