TH400 Trans Fluid Check
Old Jul 2, 2009 | 02:46 PM
tee-boy's Avatar
Default TH400 Trans Fluid Check
What's good way to check trans fluid on a TH400? Take it off trailer, make a pass, check in pits with engine running?
Old Jul 2, 2009 | 08:41 PM
forcd ind's Avatar
warm it up, run the shifter threw the gears, put it in park, ck fluid level
Old Jul 3, 2009 | 11:01 AM
black01_WS6's Avatar
I would take it off the trailor, drive in the pits up and back going thru the gears, come back set it in park running and then check the fluid after it is warm.
