Help 4L60e hard 1st shift
Old Jul 6, 2009 | 08:45 PM
edward361's Avatar
Default Help 4L60e hard 1st shift
I'm getting full line pressure from park to 1st and 1st to 2nd, the trans. code is P0748 which is the pressure control solenoid. I replaced the PCS and also replaced the TCC enable solenoid and wiring harness in the trans. This did not solve the problem. This engine & tranny is out of a 99 camero ss and is in my street rod, I used a painless performance wiring harness. the trans. always worked this way since the install. everything else seems to be working good. I even ran power through the harness to make sure there were no breaks in the harness. I also checked all the resistance in the rest of the solenoids and thay all checked out good. Does anybody have any suggestions. Thanks!
Old Jul 6, 2009 | 08:52 PM
performabuilt's Avatar
LS1Tech Sponsor
PO748 is a PCS electrical code if you have absolutley verified a complete curcuit I would have to look at the controller at that point
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jul 7, 2009 | 03:39 PM
edward361's Avatar
I've tried a diffrent PCM and it acts the same.
