Stall for LT1 (Heads Cam Car)
Old Nov 15, 2003 | 11:39 PM
Leatherneck's Avatar
Default Stall for LT1 (Heads Cam Car)
I've got a 97 LT1 w/GTP Heads, Hot Cam, All bolt ons, 3.73's. I'm currently running a Vig 2800 and when I went to the track after the Heads install I gained 5 MPH but kept the same E/T... Probably due to a jacked up trans... I am thinking about going with a yank 3500 or 3600. The Vig seemed to MPH very low, I'm looking for something with good efficiency so I have some *** from a roll. Unfortunately most of the Yank converter selection charts are based on LS1 applications. Any help is greatly appreciated!
Guns
Old Nov 16, 2003 | 09:15 AM
onebadz's Avatar
You should check out yank I think the SS4000 would be a good converter for your setup and its very efficient so you might pick up a couple MPH. I think this converter will compliment your H/C and 3.73s very well. Good Luck man
WeS
Old Nov 17, 2003 | 11:22 AM
Thanks! You don't think it will be too much for a car that still sees some daily driven miles?
Nick
Old Nov 17, 2003 | 11:37 AM
foff667's Avatar
LS1TECH Sponsor
depends really on where your powerband is...have you had the car dynoed? I wouldnt go with that big of a stall on an lt1 car unless your making peak hp at like 6400rpms...tops id go with on your car would be a tci 3800 or soemthing like that from yank...but im also going in blind just knowing your combo...it really depends on where your PB is and what the car likes.
lata
Bill
Old Nov 17, 2003 | 12:43 PM
Shon Herron's Avatar
Yank ST3500.
