I need trans help.
Old Jul 21, 2009 | 02:05 PM
BadAssBowties's Avatar
Default I need trans help.
My reverse clutches went out and i cant see paying $1000 just to repair the reverse. I want to know what i can get a 4l60e out of to put in my car.
My car is a 98 trans am and the 5.7 threw a rod and i put a 5.3 in it. it still has the 5.7 harness and ecu. I was told a 5.3 trucks 6l60e is completely different and will NOT work in my car. So my main question is, Will any LS base 4l60e work in my car with the factory harness?
Thanks in advance for any and all help.
Old Jul 21, 2009 | 04:01 PM
performabuilt's Avatar
LS1Tech Sponsor
Yes as long as its 2wd and with truck units you will have to swap the linkage shaft as it will be too long.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jul 22, 2009 | 01:45 AM
How hard is that? Something i could mess up like i did my reverse? Thanks
Old Jul 22, 2009 | 08:59 AM
LS1Tech Sponsor
no its pretty easy if you go to do it just give me a call and i will tell you what to do
__________________
Call 888-744-6542
Old Jul 22, 2009 | 09:18 AM
built408's Avatar
The shift linkage is longer, but you can get it to work. You just have to bend the cable bracket out some. I have done it before for customers on a budget. I wouldn't do it on my personal vehicle tho. Also the rear tailhousing is different, just swap it with your current one.
Old Jul 23, 2009 | 01:55 AM
Thanks. Ill be in touch.
