Looking at a TH400 with trans brake, what to look for?
Old Jul 22, 2009 | 08:53 AM
98Camarod's Avatar
Default Looking at a TH400 with trans brake, what to look for?
I've got a local guy that is selling one with a trans brake. He claims that it was in working order when he removed it. What can I look for to ensure I don't get shafted?
I know to check the fluid to make sure its not burnt or have metal shavings. But if it has been drained, what can I look for then?
Old Jul 22, 2009 | 09:23 AM
built408's Avatar
Theres not much really you can tell from the outside. Make sure it has a t-brake solenoid on the side by the filler tube. Hopefully its a short tail, which the tailhousing is about 3 inches long. 400's are some pretty stout trannies, you should be ok.
