4l80e Trans brake help needed
Problem fixed. The TCI wiring harness was put together wrong. The wire that I thought went to the "W" terminal on the transmission did not. It passed through a rubber grommet on the back side of the connector and was aligned with the "W" but went somewhere else. The rubber grommet as a hole for every pin and is supposed to line up respectively. It didn't. The solenoid I heard clicking was a different one and had nothing to do with the brake. I repinned the harness and it works like a champ. Thanks for all of the help.
I rememeber that.
__________________
