4l80 question
Old Jul 25, 2009 | 12:27 PM
blue t's Avatar
Default 4l80 question
Why does the rear cooler line have the tube on it? Do I have to use a fitting with the tube on it?
Old Jul 25, 2009 | 12:29 PM
performabuilt's Avatar
LS1Tech Sponsor
The tube is part of the lube circuit and yes it must be there or you will cook the planets real quick
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jul 25, 2009 | 04:16 PM
blue t's Avatar
Thanks does anyone sale AN fittings for these or do you have to make your own?
Old Jul 25, 2009 | 08:04 PM
forcd ind's Avatar
heres one if you have the room, otherwise weld a 90 deg steel one on it, mark where you want it to end up while its tight-being that its a straight thread, no other way to have it end up aiming the way you want
http://www.purechoicemotorsports.com...cat/cat135.htm
Old Jul 25, 2009 | 09:36 PM
blue t's Avatar
I have mine welded now but they should really think about making those with a 90.
