Will the TH400 from a Supra fit on the LS1?
Old Aug 13, 2009 | 01:35 PM
Jays_SSZ28's Avatar
Originally Posted by wajouba
But it would be better to get one from a chevy because the bolt pattern will fit the ls1 (especially the 98) with minimum modification right...
Well yes. A built transmission that doesn't fit isn't of much use.
Old Aug 13, 2009 | 06:20 PM
Mike454SS's Avatar
Fitting the 98 versus any other year LS1 is the same. GM modified the bolt pattern by 1 bolt from old chevy to LS1 and newer Chevy...they did it because they wanted to make the engine shorter. Part of this included pulling the bellhousing flange in towards the pistons, and the upper right bolt as a result would have stuck into the #8 cylinder, so they relocated that 1 bolt but left the other 5 the same...so a trans that came on an older chevy will bolt right on, short of 1 bolt, and vice versa, new trans works on older chevy less 1 bolt...there might be some issues with flywheels/flexplates and crank bolt patterns and crank flange locations...but they're all solvable issues.
Old Aug 13, 2009 | 07:10 PM
slow67's Avatar
Gingervitis Addict
actually some 5.3s have the boss for the top right bolt.
Old Aug 13, 2009 | 07:22 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Originally Posted by Jays_SSZ28
BOP means Buick, Oldsmobile, Pontiac. Those wont work on an LS1.
A BOP TH400 will most definitely bolt up to an LS1 as long as you use a BOP-to-Chevy transmission adapter plate. I have a build-up in progress.
