tranny help
Old Aug 6, 2009 | 06:09 PM
fast93z28's Avatar
Default tranny help
ok i have a 93 camaro ...cam and bolt ons....
i have the 700r4 i believe well i got it rebuilt like in the end of april ....
now if i go wot and go through the gears first to second works fine and pulls hard but when its time to shif to third i put it in and it wont shift it just goes till it hits the limiter ...when i let off it finaly shifts ......
fluid looks good ... not sure if the cable for the tranny is adjusted rigt or if that would even make a difference ........
any one have any ideas
Old Aug 6, 2009 | 08:16 PM
performabuilt2's Avatar
LS1Tech Sponsor
the first place to start is with the cable...give it a litttle slack and see what happens this will give you less throttle pressure and see if that makes a shift that way..
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
Old Aug 6, 2009 | 09:54 PM
fast93z28's Avatar
also if i leave it in d when i punch it it doesnt down shift just stays where ever and has no go at all
Old Aug 7, 2009 | 12:05 AM
performabuilt's Avatar
LS1Tech Sponsor
Sounds like there is and issue with the TV CABLE or the THROTTLE VALVE ITSELF I would check the TV cable and if all is good there its time to check the valve body
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 7, 2009 | 01:57 AM
fast93z28's Avatar
still same thing really tell a lil difference in regular driving
