4l60 shifting problems
Old Aug 15, 2009 | 06:29 PM
steve000's Avatar
Question 4l60 shifting problems
I recently rebuilt my 4l60(non E) with; billet 4th servo, beast sunshell, alto red clutches, input drum reinforcement sleeve, 13 vein pump, 3200 stall from edge, new seals, etc. The governor was checked by trans shop.
I also put in the transgo 2-3 shift kit and now it doesn’t shift into 3rd. I went through the valve body multiple times cleaning, checking valves, checking my work and to no avail.
So I took it to a trans shop and we rebuilt the whole thing, double checked the shift kit and everything seemed correct. Installed it and still no 3rd gear.
Ideas????
Old Aug 15, 2009 | 07:35 PM
performabuilt's Avatar
LS1Tech Sponsor
When you say no 3rd gear explain exactly what you mean ? What happens at the RPM its suposed to go into 3rd gear?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 15, 2009 | 07:55 PM
steve000's Avatar
Once it is in decent rpms in second over 2500 for instance and i take my foot off the accelerator the rpms drop to 1100 or so and when i re push the accelerator it goes back into second and accelerates. It shifts fine from first to second.
Old Aug 16, 2009 | 11:02 AM
steve000's Avatar
can i put a valve body from a year or 2 back into and have no problem? That way i can delete the shift kit? The only difference I have seen is there is another check ball that late model 700s dont have
Old Aug 16, 2009 | 06:45 PM
PedaltoMetal's Avatar
Did you air check the drum before installing? What was the clearance on the 3/4 pack? Did you replace the 3rd accumulator check ball in the case? Is the TV cable adjusted correctly? What year is the trans?
