03' 4L80E what upgrades do I need to do?
Old Sep 2, 2009 | 09:59 PM
flywheel's Avatar
Default 03' 4L80E what upgrades do I need to do?
Im putting an 03 LQ4/4L80E combo in my 71 chevelle. I putting a TR cam w/ .600 lift and 230/236 duration and a yank 3200 stall convertor. Question is, what upgrades will/should I do to the 4L80E before I put it in? Is there a shift kit that would be good to use? Or anything else? This will NOT be a car that will be raced just cruises/shows only street use. Thanks for the help.
Rick
Old Sep 2, 2009 | 11:10 PM
jakeshoe's Avatar
If you are going to install it without a rebuild, I would suggest installing the TransGo HD-2 kit.
That's about all it needs to be pretty reliable to ~800 HP.
Old Sep 3, 2009 | 08:50 AM
Randy WS6's Avatar
Im with Jake on that one, The shift kit will help stop clutch wear.
Old Sep 7, 2009 | 10:38 AM
flywheel's Avatar
Thanks, guys.
What will the shifts feel like? Will they be adjustable? I really don't want this to snap my neck on normal shifts, merly to shift firm.
Rick
Old Sep 7, 2009 | 07:21 PM
jakeshoe's Avatar
It's adjustable on install.
You can control shift firmness with the EPC.
Old Sep 9, 2009 | 07:10 PM
flywheel's Avatar
Thank you Jakeshoe. I appreciate your input..
Rick
