more trans problems please help.
Old Sep 6, 2009 | 05:30 PM
transam001's Avatar
Default more trans problems please help.
i just got the trans working right now its messed up again.. ok i have a 4l60e build to handle more than my power.. i also have a pt4000 converter.. i have no over drive and first dont work eighter.. if you manually pull it down into first it will work just fine.. it started acting up after i raced a vette. man it left hard lol.
Old Sep 6, 2009 | 05:33 PM
transam001's Avatar
also the converter dont lock no more.
Old Sep 6, 2009 | 06:23 PM
transam001's Avatar
i got it fixed. it keeps putting the trans in safe mode. how can you keep that from happing.
Old Sep 6, 2009 | 07:41 PM
performabuilt's Avatar
LS1Tech Sponsor
remove the test for the code po757 from tuning its a common issue with a high stall. information about it is in the stickies and a couple hundred other places in the forum. look at the stickies at top in one of the threads it tell how to do this with hp tuners
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
