Where can I get this fitting??
Old Sep 8, 2009 | 06:06 PM
camar0corey's Avatar
Default Where can I get this fitting??
Looking for another fitting like the one that came with the B&M cooler I have here. Its the fitting that will thread on the transmission line, they only give you one, and after quite a bit of reading around here going to not run the factory stuff in the radiator. Going to run just the cooler. Problem is there is only one of those fittings out of the four that came with the cooler. Need a second one, where in the world can I get it? Went to Lowes, Home Depot, Napa, Advanced Autoparts, Autozone, and a local hardware store. No luck.
Old Sep 8, 2009 | 06:29 PM
01ssreda4's Avatar
pic please?
Old Sep 9, 2009 | 12:02 AM
Old Sep 9, 2009 | 12:49 AM
salemetro's Avatar
Any plumbing store should have them. Kinda weird...here Lowes, Home Depot have them. Worst case, any place that builds lines...around here we have a place called Fluid Connector Products....but I'd imagine just about any city has some place similar. What is it...a 3/8 barb fitting?
Old Sep 9, 2009 | 08:07 AM
I suppose that is what it is, but no one had it with the same size for the hose. I had only found one place that even had the right size for the thread it self, and the diameter is smaller for the hose, the hose won't fit tight on the only female threaded one I found in town. I went to B&M's page, didn't see it listed anywhere.
Old Sep 9, 2009 | 12:14 PM
01ssreda4's Avatar
They have a small section in home depot that has a bunch of brass fittings just like that. Just have to search through and find the pieces to make it work.
Old Sep 9, 2009 | 12:46 PM
forcd ind's Avatar
is it 5/16 or 3/8 on the tube side, and is it a female 1/4" pipe or female flare on the other end-hard to see the pics
hard to tell from the pic-they generally send fittings as if you are using the fact. cooler also, prob had 5/16 lines
i had some fittings left over thru the years from diff coolers
do you need the fitting to screw on to the cooler?
Old Sep 9, 2009 | 02:13 PM
Randy WS6's Avatar
I have a 2 extra ones, because i use stainless steel braided hoses, But for what it would cost to ship them to you, you could buy a box full. , I believe the fitting is a (3/8" male barb fitting with 3/8"npt female). about any hardware store, auto part store will have them . I know Advance Auto has them , were there transmission coolers are, on the shelf.
Old Sep 9, 2009 | 03:07 PM
I'll check a different Advanced Auto than the one I was in. I swear you can never find what you need in FL. I do think its a 3/8" male bard and 3/8" npt female, I know the 1/4" stuff is too small. Its the fitting B&M supplies that fits the hose they supplied with the cooler, and it screws directly onto the transmission line fitting. They only supply one I suppose due to them assuming everyone will also run the factory cooler? There was 4 fittings in the box, all of them different.
Randy it says you are in Kentucky? Shouldn't be more than a stamp or two to send a fitting? Let me know what you want for it, if you have paypal I'll send it. Trying to get my friends Formula out of the driveway.
forcd ind, I just need the fitting that screws onto the factory transmission lines. Going to not use the factory cooler, just need a second fitting like pictured to do that I guess.
This is the cooler that is being installed:70268 Description says inlet/outlet size is 3/8.
Old Sep 9, 2009 | 07:57 PM
forcd ind's Avatar
if i can round up one i'll send it-does it screw on to the line from the trans, so it would have to except a male flare?
Old Sep 10, 2009 | 09:29 AM
Yes, it screws right onto the line from the transmission. Looking at it now I see what you mean about the flare.
Old Sep 12, 2009 | 06:24 AM
Any luck finding one anybody? I might check out this hydraulic shop today if they are open. I guess if I can't find one by Monday I will call B&M and see if I can order one.
Old Sep 12, 2009 | 06:52 AM
01ssreda4's Avatar
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Old Sep 12, 2009 | 02:05 PM
I just worry about that barb section being smaller than the one I have here? If they were different sizes couldn't that do something funky to the pressure?
Old Sep 12, 2009 | 04:26 PM
forcd ind's Avatar
i have been pretty busy, but i found a couple, both have a 3/8 barb, but the female ends are diff-1 has a 5/8" opening flare, the other 1/2"
if you measured your male fitting outside dia, what is it(hope that came out right, lol) mine are not metric
Old Sep 14, 2009 | 06:10 AM
LS1MCSS's Avatar
It looks like a 3/8 inverted flare to 3/8 barb fitting. If Lowes or Home Depot don't have it, then they are in sad shape.
